Help, will 243 casting head work w/my cam
Old 12-25-2007, 10:56 AM
04goatman's Avatar
Default Help, will 243 casting head work w/my cam
Hey guys, I need ur input on this. I acquired a 03 zo6 243 casting heads & I like u guys to tell me if this cylinder heads will work with my cam. The cylinder head has a 3 angle valve job,dual coil manly spring capable of .0650 lift,seals,titanium retainers 1500 miles ago. I plan on porting the heads then install it on my 04 GTO A/T. Here is the mods to my car: comp cam xr 275 222/224,566/568,112 LSA. 2800 stall torque converter,stainless works off road headers,drag bags, slp rear sway bar,tune. 363 RWHP. I just started doing this & fairly new to this.
Since the springs on the head is capable of .0650 lift & the cam exhaust lift is 566/568, does this mean i am ok & there will no problem if i install this head on my car ? Does anyone know any good shop in Illinois I can have the head ported & get em checked out ?
Old 12-25-2007, 01:32 PM
Evans752's Avatar
With the cam you have and 2003 LS6 heads you are talking about with the springs youe are talking about I whould say with the lift 568,566 lift cam and not that much duration, I am assuming there stock and un decked (milled) I dont see any problem with that set up, I wouldn't be afraid to do it, I would go for it. Good Luck
Old 12-25-2007, 01:44 PM
JBIRD02's Avatar
Heads and cam will work fine, but the dual valve springs are way overkill. I'd expect about 400rwhp.
Old 12-26-2007, 01:04 PM
04goatman's Avatar
The springs came with the cylinder head assembled. I don't know if the heads were milled by previuos owner or not. Thanks for the input guys.
Can anyone recommend good shop who does the porting & have it checked out ?
Old 12-29-2007, 12:56 AM
04goatman's Avatar
Come on guys, can anyone recommend me where i can get my heads ported ????
