Wahoo!!! LS6 Intake Manifold
In my attempt to become more mechanically incliended, I was reading, "LS1/LS6 Performance" by, Chris Enders and found out that I, and all 2001 and 2002 LS1's (F-body or C5) have LS6 intake manifolds. Anyway, thought I would share, the book has some good stuff that is tried and proven, so you can learn from others mistakes.
Re: Wahoo!!! LS6 Intake Manifold
You've got to be carefull about the EGR specifying whether you have a LS1 or an LS6 because my 98 corvette engine doesn't have EGR and it's an LS1.
EGR=Exhaust Gas Recirculation. Emissions bullshit. Does nothing for performance. Pumps in exhaust gasses back into your intake to cut down on hydrocarbons that may be missed by the cats.
I have heard people say that it hurts performance to disconnect it. I have heard people say that disconnecting does nothing. But I would believe if you could lower your intake temp, by not pumping in 300+ degree dirty air, you would have to realise at least a small perf gain?
Yes, EGR = Exhaust Gas Recirculation, but I always heard that the purpose of the EGR was to reduce NOx emmisions by reducing combustion temperatures, I don't think EGR does squat for Hydrocarbon emmissions.
One thing that is overlooked about EGR is fuel economy.
Exhaust gases can be considered an inert gas. That means you can fill the combustion chamber with an unburnable gas and use less fuel to achieve complete combustion. When you lower combustion temperatures in this manner you can increase your lean burn potential under cruising and light load conditions. Think of it this way. When you lower the combustion temperature you can lean the engine out more without knocking.
Therefore if the ECU is programmed correctly you have the EGR working only under light load and cruising conditions. The beauty of computer control is that when you give it any kind of throttle the computer turns off the valve. Hence, no change in performance be disconnecting the EGR system.
Since I am using a race computer on my corvette engine I am slightly bummed that I don't have EGR because my potential fuel economy is lowered.
Mark
Mark
yes mines EGR but id heard about some EGR-less ls1 intake cars overseas or something.
I don't know anything about overseas EGR-less LS1 intakes.
OK I thougt you didn't have egr stock. I'm really surprised that 01-02's dont.
