H/C worth it?
H/C worth it?
My camaro has 77k on the clock and I was wondering if the engine wouldbe worth putting Heads and Cam on? Would it be worth while waiting till I get more miles (like 100k-120k) and get a 383 stroker and supporting parts? Looking for BEST BANG FOR MY $. Current mods: qtp LT's and ypipe, GMMG axel back, ls6 valley cover, elctric water pump, double adjs CA, weld on anti squat brakets, double adjs PHB, pro 5.0, ls7 clutch.
Thanks
Thanks
you could go ahead and throw a set of heads and a cam in this motor, then just switch them to the new block when you get it, but u have to think about this....choosing heads and a cam for a 346 is different than choosing heads and cam for a 383+ motor. You will most likely have higher compression and a stronger bottom end on the bigger motor, therefore limiting/expanding your range of options.
Im am with everyone on this. Go with a nice h/c setup right now. There are many who do h/c swaps with as many or more miles than your car. I wouldnt touch the bottom end until you have to. As long as you install everything correctly, buy all the supporting mods, and have a correct tune you will be fine. Enjoy!!!!
Thanks guys. I have heard a lot about AFR heads (205's). but those are a little more then 2grand. Do you guys think that these are best product out? or is there sumthing that isnt so advertised but equally capable? With the cam im guessing a custom ground cam would be a good choice? Not really to sure. HP wise im lookin 2 put 420 to the wheels. Is that an exagerated #.
i just had MTI install their V1 cam in my car two months ago with 165k miles clocked. Pulled 400rwhp, gets 23 miles to the gl (4miles better then i did before my cam?) and burns no oil. DO IT!!
Hey allThrottle you live in Nevada but got your car tuned in Fremont California. Ive heard good things about Rick at Synergy. How was youre experience. I only live across the bay from him so that would be great.
I like Synergy alot, Im a Synergy nut swinger. I would recommend taking your car there to anyone. Thats just my opinion. Rick is the ninja master as I like to call him, when it comes to tuning. Since your not to far away from him I would say definetly take your car to him.
Well I finally got H/C put in my car. Man its a whole different car! LoL I ALMOST dont like to speed anymore just siitin at a stop light and listen to the rumble. Car was on a DynoJet and put 408/367 SAE. All the work was done at Advanced Dyno. Couldnt ask for better customer service. Very happy with the work done.
