Do I need new valve covers?
No they will not. Those are not stock valve covers....And then even if you got stock valve covers, I'm not sure the 98 coil packs/brackets will work.
98 F-bodys only had bolts around the whole valve cover...99-02 they had 4 center bolts, like what you have.
You could always just fabricate some sort of brackets to put the coilpacks in a different location and keep those cool valve covers.
I'll have to research the relocators. If they're ungodly expensive I'll just make some myself.
Jetlag, if I were to sell these coil packs and buy some from 99-02 should they bolt up? What about the wiring harness, will it plug into my 98 wiring harness?
The transmission is an SM (Muncie) 465. It's a 4 speed with a granny low first gear, so essentially a 3 speed. Transfercase is a Dana 300 which is about to receive a 4:1 low range conversion and twin sticks. The Jeep is a 1980 CJ5 with the cleanest frame / body I've ever seen.
Your choices are:
#1. Fabricate mounts for your coilpacks (be the easiest and cheapest)
#2. Sell your aftermarket valve covers and 98 coilpacks/brackets and buy 99+ covers and brackets
#3. Buy a 98 motor to use your 98 brackets (this of course is a joke)
I would take #1. You are already doing fabrication to get the LS1 in there so just do a little more. That firewall is wide open and you could make a neat coil pack holder to mount there. Just need longer spark plug wires.
He cant just change valve covers to perimter bolt 98 he would have to change the heads. Coils on all the LS1 are the same anyway. He would only need new stock center bolt valve covers and brackets for the 99 and up setup. It would be like changing heads on a 98. Newer heads needs new valve covers and brackets the coils are the same.
The motor might be out of a 98, but the heads are not, the intake isn't either. I hate repeating myself.... sorry to seem like an ***... please read post #7.
Gonna be an awesome Jeep man I don't remember where but I have seen a company that sells a coil relocation kit that moves them to the firewall. I bet you could adapt it to fit your Jeep or at least help you get an idea to help you fab something up. Maybe somebody else knows what I'm talking about and can shoot you a link. Good luck man!!
