LS1 intake manifold on 01 LS1 block ?
My brother blew is original motor on his 98 SS and replaced it with a 01 LS1, however the mechanic that install the motor installed the old LS1 intake manifold on the new block, because of the EGR, what kind of effects will this cause on the performance of the new motor, should we just install the LS6 manifold on it?
you can have the egr tuned out of the car but you will need to block off the egr port on the side of the intake manifold, i would say it would be better just to swith the ls1 intake out for the ls6. the ls6 flows better and you can get more power out of it. switching the intake only takes about 2-3 hours at most
Thats exactly what im going to do because ever since the new motor was installed i cant get rid of the Check Engine light stating code P0171 so hopefully this will solve everything.now im just going to figure out how to distinguish the difference between coolant lines.
