LS1 fans question
LS1 fans question
I am not sure and that is why I am asking, so the big fan on the passenger side should be the radiator fan and it has a high and low setting, and the small fan on the drivers side should be the a/c fan, does it have a high and low setting also and should it be on all the time the a/c is on if the car is not moving?
If the car is stock with stock thermostat and stock fan settings. You have 2 fans, they are set to come on/off when coolant temps are:
fan 1 on 226*F
fan 1 off 219*F
fan 2 on 234*F
fan 2 off 227*F
fan 1 on 226*F
fan 1 off 219*F
fan 2 on 234*F
fan 2 off 227*F
My stock fans both operate simultaneously on either low or high speed when commanded on, that started a few years back when they went to the 3 relay system.
