LS2 intake on LS1 questions
What is needed to run an LS2 intake on an LS1? I've read that the LS2 needs larger O rings on the intake side. I was looking on the speed inc site at fuel rails and they said the LS2 rails only work with factory sized injectors. Basically what do I need to make this work?
Ahhhh, then the LS2 IS the best match. The injectors will need the larger diameter bottoms. If you use the stock LS2 fuel rail you will need the short injectors also. If you use the tall ones we offer a billet fuel rail that fits the LS2 manifolds. Also, what TB are you going to use?
