maf housing question
Old 08-02-2003, 01:35 PM
RAMnGO's Avatar
Default maf housing question
i just seen an article talking about removing the airfoil in the center of the MAF housing..is this a good idea or just wasted time?
Old 08-02-2003, 01:39 PM
jd13's Avatar
Default Re: maf housing question
Basically that's porting your MAF. Some a4 cars it causes trouble with. I did it to mine and haven't had any problems. It's a hit or miss with some people. I'm sure some others will chime in with some real info.
Old 08-03-2003, 10:05 AM
Moderator
jimmyblue's Avatar
It would increase ultimate airflow. It will make
your MAF frequency/airflow scaling false (low)
and tell the PCM that you need less fuel and
less AT line pressure (lean, slip). Before you
start cutting, make sure you have the means to
fix the fix. Otherwise, welcome to "Why Does My
Car Ping and Run Slow?", contestant #8573!
Old 08-03-2003, 11:00 AM
NightHawk's Avatar
https://ls1tech.com/threads/showflat...31&fpart=1
Here's a fix if you have problems. I ported mine a while back and never had any serious problems, but my Ltrims are way too high(+18 to +23). I just did this mod and I am about to put the car back together...guess I'll see if it does the trick.
Old 08-03-2003, 11:20 AM
soundengineer's Avatar
Fixed ME!!!
DO A Full Port Job... not just a de-screen... you'll feel a difference...peak HP is not that great of a difference... but it definatel is stronger throughout the RPM Range... Both Torque and HP
