Fast and Map sensor?
Okay, i know that the fast doesn't have very good quality when it comes to the map sensor location, and thats fine. I already bought the intake, and i plan on keeping it. My question is what is the best way to make sure the map is sealed up. I have the intake on the car and i think i have a vaccum leak from the map. I just used Rvt the first time i installed the intake, but I thought about using a rubber grommet in there try to make the hole smaller, i have heard of people taping the hole and putting a hose end in there and then use a rubber hose to the map. If anyone has suggestions or other ideas or have done either of these themself some guidance would be appreciated.
Teflon tape is definitely NOT the way to go.
I think I tracked down my stalling problems to a loose MAP last night.
I like DrkPhx's idea but I'd have to pull the thing, and that job sucks.
Also, I'm guessing there isn't a difference in the 90 Vs. the 92 in this regard.
Lesson - do it right the first time...
..where have i heard that before?
Alright i will post a pic when i take it off tomorrow, i am two hours away from the car right now, at school in eau claire, WI. How far is St. Michael from the cities DrkPhx? I would definetely like to check out your rides sometime. I am moving from rochester to cottage grove the first week of june.
Isn't there an alternative MAP sensor that fits better?
Mine was working great for over a year, then started to hear a whistle as low map areas like idle and deceleration. With some throttle the whistle would go. So i tracked this down to be a loose map sensor on the fast intake. I took this off and used some tape to make the map sensor a little bigger and make it fit in the hole then used some sealant and plumbed it back in. I thought the job was done better than ever before, but not is starting to whistle again 2 months later.
If there is a map sensor that fits better I'll invest in one.
Here's what I put together..
Only took about 10 hours and 5 or 6 trips to HomeDepot and Menards.
I feel much better about that than just some RTV, but I had the old style FAST.
Fixed ONE of my idle issues.
