How many cats - 1 or 2???
So, I've had the Trans Am with the G1 cam for about 3 years now. It hasn't been my daily driver, but I'm reaching the point that I'm getting very annoyed and frankly sick of the exhaust smell.
Now, I'm wondering if I should just install one 3 inch high flow cat after the 3" collector or should I install 2 cat converters. The 2.5" inch ones before the collector?
Will I be ok with one single cat or should I get two?
Thanks......
Thanks......
anyways if you dont need to worry about smog then i don't think it really matters but if you do have to worry about smog then you need them as close to the engine as possible.
how do you figure that? my logic is one bigger cat would be less restrictive than 2 smaller cats.
I have 2 cats on mine and made the numbers in my sig. Even the shop was impressed by the numbers with cats. They are Magnaflow, BTW. I don't think I would have hit that with 1.
