What size injectors will I need?
I already have the mods in my sig but will be adding a set of TSP stg 2.5 5.3l heads and a Ported fast 92 w/ LS2 TB. Will 30lb inj's be ok or will/should I go bigger? Thanks
I have SVO 30s and I'm about 81% duty cycle and I put down 445 RWHP a Y-pipe set up. 30s are fine for N/A. But you should go bigger if you EVER think you'll take the nitrous route later. Better off going bigger now than having to replace the 30s later down the road. I thought I would NEVER hit the nitrous, but now I'm on the fence. If you're SURE you won't get 30s, if you're not sure, go 42s IMO.
I have SVO 42's and they are great! SVO 30lbs will do they are 36lbs with our fuel pressure but i got 42's and im cam only, so i never really had to buy anymore down the road when i add more mods
just installed TSP (PRC)stg 2.5 5.3 heads with MS3 cam with lucas 42lbs and worked out great!
Are the SVO 30's a direct drop in? Will having 42lb injectors cause me to have shitty MPG over the SVO's, or do you just tune them to run the correct amount of fuel therefore thet are the same?
