People with 90mm or bigger Throttle Bodies please help
Old 08-01-2008, 01:30 PM
Punisher GTO's Avatar
Exclamation People with 90mm or bigger Throttle Bodies please help
What intake are you running to match up with your larger throttle body?
if you are still running your stock intake tube how did you make it fit?
or did you buy an after market intake?
And if you did buy an after market intake did the tubing come close to fitting your larger intake?
Thanks again
Old 08-01-2008, 03:43 PM
Viper's Avatar
I bought the Fast Toys 85mm intake, used my Z06 85mm MAF and a fernco hose (3.5") from Lowes to make it work. My stock one would not fit. I use the NW90 TB.
Here are some other choices for intake tubing:
http://store.airflo.com/rubber-hoses---clamps.html
http://intakehoses.com/Merchant2/mer...ory_Code=CACH5
Old 08-01-2008, 09:09 PM
AFASTYZFR1's Avatar
I have NW 90mm tb with 90mm Fast intake
Old 08-02-2008, 05:24 AM
odarabla's Avatar
I have the NW TB, ported fast, SLP MAF and the SLP lid and I still have the stock bellows.
Old 08-02-2008, 11:00 AM
RZRSEDGE's Avatar
Ported Fast 92 and NW 92, FTP 85 lid, ZO6 MAF, and 4" Fernco. The Fernco is big; but if you trim correctly and take your time when tightening it down, it will form a nice bulge at the bottom and provide some suspension for motor shake. Looks good also. Just noticed your a GTO. Don't know much about them; but I'm pretty sure if this is the car you're inquiring about that most of what I posted won't apply to you.
Old 08-03-2008, 08:56 AM
theblur98ss's Avatar
I use an LS2 intake w/holley 90mm TB. I have a 3 to 3 1/2 silicone coupler.
Attached Thumbnails People with 90mm or bigger Throttle Bodies please help-alive-001.jpg
Old 08-04-2008, 09:22 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had a FAST 90/90 with the stock bellow/MAF and a SLP lid
Old 08-04-2008, 03:54 PM
snake charmer's Avatar
Running a Fast 90mm went to the local hardware store and spent under $10 on a 4" bellow and still run the stock MAF on the other side . It may not be an exact fit so you may have to cut the bellow till it fits .
Old 08-06-2008, 12:05 PM
Thule's Avatar
i have
FAST toys ram air. Fasttoys 85mm lid, GM 85mm maf, NW90mm and FAST90 intake,
and i have not tryed it
Old 08-06-2008, 02:38 PM
dlove's Avatar
fast 92mm tb w/ stock bellow. i took a small propane torch to the stock bellow and made it soft and then stretched it out to fit. now it fits without a problem.
Old 08-06-2008, 02:46 PM
JScamaro's Avatar
I have a Fast 92mm intake and NW 92mm tb.
Will the SLP lid fit over a 92mm inlet on the tb?
Old 08-06-2008, 02:51 PM
slowjoe99's Avatar
SHOWOFF!!
Old 08-06-2008, 07:22 PM
Jedi Master
Gh0st's Avatar
FAST92 mated to a LPE "CAI".
Quick Reply: People with 90mm or bigger Throttle Bodies please help
