if i remove the motor mount bolts?
Re: if i remove the motor mount bolts?
Yeah seriously, we are all friends here, what do you need to do? And the motor will not drop down that much as it will still be sitting on the subframe.
*Bad Trader*
if you unbolt all the bolts and nut it will not move(asumming the tranny is still attached) it will sit in there like you did nothing. you will have to rais the motor up ever so slightly and drop the mounts then you can lower the motor about 3- inches, i bottom out on the pan on the k member. trust me i had to do this a few times....
i CANNOT get the damn trans dip stick in!! 4 of us have tried and it just won't go!!!! if dropping the motor does not help i'm going to push it off a cliff!!!!!!!!!!!!!!!!!!!!! but thank's for caring!!!
Dipstick in the trans-pan? Hold on, what kind of jack are you using- I assume you are on jackstands? Are you saying you can't get it to line back in the trans? I would seriously think twice about taking the motor mounts apart. What is going on?
