How much torque to rotate bottom end?
Hey guys,
I'm rebuilding my first LS1 (2000) and have a question. With the crank only installed and torque / angled correctly, the thing will spin very easily by hand.
Now though, I've got all pistons in, and caps torque / angled correctly, but it's hard as crap to turn the crank now. Actually, it takes 78 ft. lbs. to do it. The cam / valve train is not in yet, so I'm only trying to turn the rotating assy. I have not built a V8 in years, but this seems tight to me.
Can any anlighten me maybe? My father-laws '91 5.0 (Ford) was much easier to turn than this thing is, and it was a full motor.
BTW, lots of 30 weight oil is everywhere it should be.
Oh yeah, stock crank and (new) stock bearings are used here.
Thoughts please....
Thoughts please....
I couldn't easily find plasti-gauge that met the specs. Also, We're talking about a stock crank, polished at a shop and bearings they supplied. Since I couldn't get the plasti-gauge, I figured with the polished crank and parts they supplied, it'd work fine.
From memory of past builds, I think it's too tight basically. I just don't have any history with the LSX as far as rebuilding goes. The cyls. have been honed and ring gaps are good. Lots of 30 weight is present like I mentioned before. I don't feel good continuing at this point w/o a closer look.
Are they new rods? Did you measure the big end of the rod before putting it together. It definitely sounds like there is a clearance problem.
Heck, I can get a small block 350 with the heads and spark plugs to turn over with less torque than that while installing the crank bolt.
