FTRA SSRA - how it works and why is it better than FRA
Old 08-20-2008, 10:28 AM
Ironxcross's Avatar
Default FTRA SSRA - how it works and why is it better than FRA
Discuss.
Old 08-20-2008, 10:44 AM
vjo90rs8's Avatar
search FTRA or SSRA and you will probably find 100+ threads with all the info you need. Even Fast Toys website and installuniversity.com explain how they work.
Old 08-20-2008, 10:47 AM
Tainted's Avatar
SSRA.
They both work in the same way but the SSRA has a lower scoop that faces forward which in theory should push more air in and it has a gap to let any water drain out.
Old 08-20-2008, 03:34 PM
Kleeborp the Moderator™
MeentSS02's Avatar
No. To paraphrase JRP "SEARCH ************!"
This topic has come up way too many times to warrant another thread about it.
Old 08-20-2008, 07:40 PM
Ironxcross's Avatar
yeah, im reading some links. sort of biasing towards the ssra
Old 08-20-2008, 08:19 PM
rel3rd's Avatar
I'm happy with mine...
Old 08-20-2008, 10:28 PM
camaroracer91's Avatar
i love my ftra alomst sounds supercharged at high rpm's
Old 08-20-2008, 10:42 PM
Sunset'01Z's Avatar
they are 2 different mods!! one does not replace the other. both of them work together on the car, at the same time, doing two different jobs, in two different areas in the intake system.
FRA means cutting out the airbox under the air filter
FTRA is the scoop that sits below the airbox.
still dont understand how people get these two confused...
Old 08-21-2008, 08:06 AM
z28voodoo's Avatar
hahaha no.. no it doesnt
get either SSRA or FTRA.. they work the same. SSRA hangs lower and if you park close to a curb risk hitting it and tearing it off. FTRA is a little more stealthy.. not by much.
Old 08-21-2008, 08:47 AM
plaf713's Avatar
if your running a trans cooler do you think it has any effect on it? I would think less air would make it to the cooler to make it less effective
Old 08-21-2008, 09:37 AM
yea it does i get asked all the time by people when im drivin around in first
Old 08-21-2008, 10:22 AM
vjo90rs8's Avatar
I mounted mine "dope style". Do a search and you will see what I'm talking about
Old 08-21-2008, 12:34 PM
z28voodoo's Avatar
oh.. ok. well maybe i just cant hear mine then over my exhaust.
Old 08-21-2008, 04:39 PM
ha all i have is a blowmaster muffler so maybe you cant
Old 08-21-2008, 05:20 PM
94'BLKBRD's Avatar
Go with the SUX2BU ram air
