can i delete the egr only?
Old 08-24-2008, 04:32 PM
redbadss's Avatar
Default can i delete the egr only?
i have searched this thread for a while today and i see that everybody deletes both the egr and air. can i just delete the egr and still have the air? i would also appreciate pics on how to remove it and instructions. i am probably going to use the block off plates instead of the freeze plug. thanks
Old 08-24-2008, 04:42 PM
themack56's Avatar
i used the block plate from ebay, i deleted both but u can just delete the egre if u choose to, the egr plates are one for the top of the intake and the other one for the fitting were the egr runs to on the manifold which is right next to the air hookup, they look almost alike but the egr one is a bit larger, just remove the egr hose and block it off, and block off the hose on top of the manifold just like that
Old 08-24-2008, 04:54 PM
MYSTIC-1SC's Avatar
I deleted just the egr when I did my long tube header install
Old 08-24-2008, 10:13 PM
dutinsss's Avatar
you can delete either one or both. why would you want to keep AIR though?
Old 08-25-2008, 09:16 AM
udienow's Avatar
Yeah what he said... idk why ud want the AIR though. Just remove both..
Old 08-25-2008, 02:43 PM
00_transam_vert's Avatar
This may sounds like a stupid question, and Im not tryn to insult you, but you do mean the A.I.R system right? not your a/c?
Old 08-25-2008, 07:41 PM
Nauty99SS's Avatar
yes he means the a.i.r .. i just removed only my egr
Old 08-25-2008, 07:46 PM
1sick'98WS6's Avatar
All you need is a freeze plug and a block off plate, Almost easier to not deal with it until you do headers, that is if its in your plans
Old 08-25-2008, 08:15 PM
LS184's Avatar
take both out....and hell while ur at it take off ur a/c 2 lol
Old 08-25-2008, 08:17 PM
LS184's Avatar
here are instructions on how to remove the egr http://www.installuniversity.com/ins...sity/index.htm click install documents on the left sid enad find egr free mod
Old 08-25-2008, 11:58 PM
bww3588's Avatar
he may still have cats.....thats why.
Old 08-26-2008, 04:53 PM
redbadss's Avatar
yes i was referring to the a.i.r. system not the a.c., and i still have my cats so i still want the a.i.r., thanks for all your help guys..
Old 08-26-2008, 08:31 PM
Camarokid08731's Avatar
i deleted both with stock manifolds and cats after i tuned out the ses light on the hp tuners it was smooth sailin after that
Old 08-27-2008, 12:20 AM
integraxtc's Avatar
so is it bad for the cats to delete a.i.r??
I was planning on deleting egr/air and getting some high-flow cats for when I go and do my full exhaust.
Old 08-27-2008, 03:00 PM
it didnt hurt mine
