Whats the best spark plugs?
Should I stick with AC delco? or somthing eles and how often are u supposed to replace them in the LS1's? every 24,000 miles?
I use NGK TR55's, they are the best ones. But your engine was designed with AC Delco's, so they will be perfect.
Even with stroker engines, just use NGK or AC Delco. You won't get better performance with any others.
Change them every 50,000 and you'll be fine, unless you have certain issues internally.
