Y Pipe Options For Pace Setters
I Have Done The Searching For About A Month, Havent Come Up With To Many Difinitive Answers As Far As A Y-pipe Setup That Is Liked With The Pace Setter Long Tubes. I Want To Go With The Flowmaster Merge And Such But Not Sure Exactly What I Need To Buy. The Texas Speed Ory Is Also An Option.
1. First Of All I Have A 3" Magnaflow Catback, And I Need To Know Which Merge Will Fit This Or How I Can Make The Merge Fit.
2. Second I Would Like To Know How You Attache The Collector On The Headers To The Pipe And What Size Pipe Should Be Used With Whichever Merge I Need To Hook Into My Magnaflow.
Any Help.......greatly Appreciated.
The TSP ory pipe is good but ground clearance isnt that great. I just went with the pacesetter ory pipe for better ground clearance and I plan on welding in the flowmaster merge collector soon.
Well, youre gonna have a hard time finding a store bought y pipe with a merge as good as the flowmaster. Im not sure which one, but I think one of the higher dollar header companies has a y pipe with a true merge. It might be QTP or Kooks. Either way, youre gonna pay. I would find a good shop and have one custom made. That will ensure proper fitment and great clearance. It will most likely be less costly too.
Those revised LPP stainless headers come with a great looking ory. U ought 2 check out pictures of the merge posted in one of these recent threads. Good prices 2!
2 = From the headers you will need a 3 inch pipe, as the pacesetters are 3" and the entrance on each side of the flowmaster merge is 3" as well.
I suggest getting a custom made y-pipe w/ the flowmaster merge made right off the bat...
oh and i forgot to ask... aint it a bitch to cap every letter of every word like that? It Would Drive Me Nuts To Stop And Press Shift To Cap Each Letter. Really slows down my typing...
1 = You can use either the dual 3" in to single 4" out OR the dual 3" in to single 3.5" out... both will work... i am getting the dual 3" in, single 3.5" out installed today. After that you will need a reducer down from either 4" or 3.5" (depending what you pick) to 3" so that you can connect to your magnaflow cat-back.
