GMMG, LT(with CATS)=Worth it??
Hmmm,
I have a GMMG muffler, and want to add LT, but I NEED to keep the CATS.
Will I still gain hp from the LTs even if I keep my CATS? If yes how much approx?
Thanks.
Thanks.
Tech Resident
You can't use stock cats. You have to buy high flow cats. You can either buy a catted y-pipe from the same manufacturer as the LT's or you can buy your own cats and have a custom y-pipe made.
you wont have near as much rasp with cats, but might lose 5hp at most. Yea id say its worth it, especially considering that gmmg is one of the "the" best sounding exhausts on the market
Yep most catted ypipes come with the appropriate highflow cats and bolt right up to the headers and the catback. You might lose a slight amount of HP using the cats, but it will be much better than stock
Thanks for the help.
I just need to find out if I can use the hi flow cats, as I dont think they will pass our emmisions test.
I do know some friendly testers, but I will be moving abroad, and can't rely on friendly testers for long.
I will find out more about our emissions test.
Thanks again,
Paul.
Thanks again,
Paul.
Thanks again,
Paul.
Thanks again,
Paul.
I passed my emission with high flow cats. They still get the job done for emissions. The high flow cats just flow the exhaust better while still getting good emisions. gets the longtubes, high flowcats that should come with the aftermarket y pipe you will get with your longtubes.
I have spoke to a couple of testers, and they are not sure if the hi flows cats would pass emissions or not.
I can get the LT here really cheap, but the catted y is $$$$$$$ with shipping & taxes. Even a custom y isn't going to be cheap by the time I add the cats and labour. And it still might not pass our emissions.
Mabey I should just get a cutout. Would that gain me much hp over my current set up? (Stock header & y pipe and GMMG).
Thanks for all your input guys....
