how many of you guys have had their lts welded to your ory
i have pacesseters lts and right where the collector meets the ory i have had a leak that i cant stop. i have had to diff. set of band clamps with no luck thinking about maybe having it welded shut.
i would try something like this before i welded the y pipe to the headers
http://www.jegs.com/images/photos/28988310.jpg
Search isn't working for me. Not too long ago someone posted about these:
http://store.summitracing.com/partde...dtc-60-912300s
Basically you weld the supplied flanges to your collector and Y pipe and then that V clamp mates the collector and Y perfectly.
I'm using those Dynatech clamps in my exhaust from the headers to the Y and at the back. What I found is metal to metal will not give 100% seal. But Mr.Gasket makes graphite sheets with metal mesh in it that you can cut circle gaskets out of. I put those in my clamps and it is 100% tight.
I have mine welded because I bought a used set that was previously welded and didn't have all the clamps. It's not a big deal, unless you're removing your exhaust constantly. It's easy enough to cut and weld again if you have to remove it.
I agree. I welded my td's to the headers after trying lots of different clamps that eventually leaked. I didn't really want to do it, but in reality the only time you would need to remove your exhaust is if you need to pull the trans or cyl heads. Like was mentioned above, just make a clean cut and weld again.
Hate to see you weld them. Here is the material to make nice gaskets that will not leak. I should just punch them out and sell them here for all V-Band users.
http://store.summitracing.com/partde...5&autoview=sku
