Springs for gt2-3 for mantinence free
I have a gt2-3 cam going in my truck with a magnacharged lq4. The boost is going to be stock lvls so 5-6psi. I am going to leave that as it is and this is my DD with 20k miles a year. That said I am trying to pick springs that will last me a long time. Here are my choices
yellow ls6 - oem designed for life, but gt2-3 cam seems to max out springs and I have boost
Comp 918 - can take the lift of the gt2-3 and have more spring pressure. I am unsure on how long they will last?
PRC Duals kit which includes ti retainers - way overkill for the gt2-3, but would this give me long life?
Thoughts?
Thoughts?
This is my 20k/yr DD running a max of 6psi of boost. The cam is a lingenfelter gt2-3. What I want is the longest lasting spring I can get. I will bring the truck to the track... but i'm not going to make it weekly event
LS1Tech Premium Sponsor
I've personally checked PRC springs after 50k miles & they were still useable. While I like to see them checked ever 25k miles, I feel like the PRC spring will provide you with a long trouble free life.
All PRC spring kits uses components made in the U.S. Each retainer is carefully inspected to make sure install heights stay correct to help provide proper pressures on every valve.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Trick is the OP doesn't really need so much spring pressures though, that is why I said comp 921s.
