Coolant Crossover???
I was looking at the install article for switching from my stock LS1 intake to the LS6 and it mentions that I need '01-'02 front coolant crossover and plugs for the rear.
My problem is that none of the parts sites I know of have a current listing for the part numbers provided.
Are the later style cross over and plugs 100% necessary?
Is it possible to use my existing cross over?
Does anyone know a resource to attain the parts?
-Thanks
-Tim
-Thanks
-Tim
Some people grind down the bottom of the ls6 to make the ls1 fit. Here's where I got them. http://www.texas-speed.com/shop/cate...MID=1&catid=12
LS1Tech Premium Sponsor
We've got those in stock, Tim! Let us know if we can help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
UNDER PRESSURE MOD
I ran my ls6 intake with the stock crossover in place for a long time. Some people say that it's better to have the stock crossover in place because it helps to balance out the front to rear cylinders.
Unfortunately, you can't use it with the FAST, so I had to switch.
I say keep the stock crossovers and just trim the casting flash off the ls6.
The $49.99 you spent gets you the cross-over for the front and plugs for the rear
You should have tracking numbers in just a bit as soon as UPS picks that package up!
__________________
