Anything I should inspect while the Oil Pan is out?
Expect the oil deflector LOL. Is the motor still in the car? Is the motor out of the car? Quite a few things you can do to upgrade the block whether the engine is in or out...it just depends.
Well Everything looked good in the bottom end.
I replaced the oil pump o ring while I was at it.
I have an automatic so i dont plan on having it shift past 6k. So I left the rod bolt alone for now. From what I could see the piston walls looked ok, didnt see anything wierd.
