Help: BAD misfire everytime I hit a puddle '02 SS
Old 11-02-2008, 12:26 AM
JettRink's Avatar
Default Help: BAD misfire everytime I hit a puddle '02 SS
So for about a year now, I've been tolerating/avoiding rainy weather, puddles, drive thru car washes, etc. Why? Ever since about a year ago or so, when I go over a puddle/enough water to splash up into my engine bay, i'll get problems characteristic of a/multiple misfires, i'll get the flashing SES light, and my car feels like death. Eventually, it'll dry out, correct itself and back to normal, provided I don't get it anymore wet. I've inspected the plug wires, coilpacks, nothing irregular. My mechanic can't figure it out, and it's getting old, having to bum rides anytime it's raining out. Any thoughts? My mods are as follows:
Camaro SS 2002
Pacesetter LTs
Magnaflow Cat
ORYP
Dynomax bullet muffler
Free ram-air mod
Thanks all, really appreciate any insight here. This sucks.
Cheers
Old 11-02-2008, 11:00 AM
Grimes's Avatar
sounds like water is messing with your 02 sensors or O2 sensor wiring. I would check those things first.
Old 11-02-2008, 11:05 AM
7camaro7's Avatar
check spark plug wires too
Old 11-02-2008, 11:14 AM
heavymetals's Avatar
Maybe you should try a small spray bottle of water when the car is ok.
Spray different areas and see what happens.
Old 11-02-2008, 11:45 AM
98Camarod's Avatar
That sounds like the only thing you can do if you can't see anything.
Old 11-02-2008, 11:46 AM
GT Griller's Avatar
Some times getting alternator under water since its on the bottom half of the engine will cause these issues.
Old 11-02-2008, 11:49 AM
DONAIMIAN's Avatar
+1 I had that same problem.
Old 11-02-2008, 01:07 PM
PONTIAC SLP's Avatar
same problem with me too i changed the plugs , mass air and coils and it's the same problem then i put the car under cover
Old 11-02-2008, 01:18 PM
7camaro7's Avatar
I use some of that dielectric gel on my spark plug wire connections too to keep water out. also mine hasn't done it since I've turned all my wires 90degrees on the same connector they are on. I think when they are crimped from the factory at msd, some of them weren't tight enough. Mine hasn't had that problem since and I've driven through heavier rain than when I used to have the issue.
Old 11-02-2008, 01:20 PM
black01_WS6's Avatar
same thing happened to mine- it was the o2's. The place I took it to orginally put in new o2's when I blew one out. Well they put a new one in but did not seal it properly and had water hitting open wires- hence only messing it up when it got wet.
Old 11-02-2008, 02:15 PM
guys if the plugs is black or white what its means ?
Old 11-02-2008, 03:20 PM
DropTopBird's Avatar
If the spray bottle thing doesnt work and you have access to tuning software, you might want to try logging driving time when its rainy. That might be able to help you see exactly whats causing the misfire.
Old 11-02-2008, 03:46 PM
got-a-ls1's Avatar
yea if you know anyone or if you have hptuners you can force the car to run in open loop mode using the vcm controls. the computer shouldnt use the o2 sensors in open loop. That could rule out the problem.
Other then that i would invest in a tube of die electric grease and get to work...
Old 11-02-2008, 04:16 PM
JBIRD02's Avatar
Yep, he's right. I had the same problem. Turned out to be water in the connector for the O2 sensor & O2 extension causing it to run horrible. I unplugged them, dried them out really good, then loaded them up w/ dielectric grease & wrapped them up. Problem solved. I have since switched to the Bosch 13111's which are longer and have no need for O2 extensions, and still problem free. Good luck.
Old 11-02-2008, 06:32 PM
JettRink's Avatar
Thanks for all the helpful insight guys. This week I'm going to try disconnecting the O2 wires and sealing them w/a few layers of electrical tape, then see what happens. Again, I really appreciate the fast and detailed advice.
Cheers
Old 11-02-2008, 09:22 PM
JBIRD02's Avatar
Cheers
Welcome!
Old 11-02-2008, 09:28 PM
devious's Avatar
I hit a puddle one night and my car ran like death,floored it and it ran great, once i let off it ran bad again, just a simple way to diagnose IMO. Hope this helps!
Old 11-02-2008, 09:55 PM
m6camaro's Avatar
Had the same problem, it was the O2's.
Old 11-02-2008, 10:11 PM
z28fury's Avatar
Just seafoam it. It will fix everything forever.
Old 11-02-2008, 10:35 PM
wht01ws6ta's Avatar
Think if the plugs are black its burning rich or oil getting sucked into the cylinder and if its white then running lean/hot. by the way I visited those towers in your youtube video a couple of months ago
OP, if taping up the O2s don't work are you going to try going around with a spray bottle to see if you get a reaction?
