where to find torque?
Old 11-03-2008, 06:19 PM
cammedss2000's Avatar
Default where to find torque?
I dynoed my car and it did 430hp and 383tq with an m6. I want more torque. My current setup is
Fast 92/92
Ls6 stage 1 heads
ms4 cam
42# injectors
lid
pacesetter longtubes
y pipe
slp exhuast
stage 2 clutch
Would it be a good idea to increase the compression. Would a new head gasket that is thinner maybe .30 help any. Shave heads flycut the pistons............ I just want to see that tq go up. I honestly thought it would of been higher. But the dyno shows a smooth pull on the graph up to 6700rpms. I scanned the car and looked at the ve tables and they were pretty rough. This is after I paid 400 dollars for a dyno tune. Dont the tuners usually smooth that out. I did not look at my timing. Bottom line is tq. Hp is a lot easier to get. Tq is what I dont get. I would like to keep this setup for now at least. Any input would be great thanks!
Old 11-03-2008, 06:41 PM
Shawn MacAnanny's Avatar
When you add the cylinder heads, and cam you greatly decrease you dynamic compression ratio which great decrease torque. You can mill the heads and flycut the pistons and run a thinner gasket but only so much and you will HAVE to run 93 but i could see you picking up an each 30rwtq. You coul also add and x pipe (if you have room) for probably another 7-10rwtq.
Old 11-03-2008, 06:51 PM
Hi-Po's Avatar
What LSA MS4 did to go with? Too big of cam IMO, especially with a shitty tuner.
Old 11-03-2008, 07:49 PM
It is a lsa 112. I think the tune could be better. I see autos pushing more torque then me. I threw all this money on this fast manifold too. I feel I could have done without. I thought timing played a big role in torque? Should I take it too another tuner.
Old 11-03-2008, 07:54 PM
07gsxr750's Avatar
Second that, your comp. is to low, I am running 12.5:1 and I made 428rwtq on my setup in my sig.
Old 11-03-2008, 08:05 PM
LS1-450's Avatar
Do you have a copy of the tune file or the scan you made? What's the A/F ratio @ peak torque? The tune file will show where the timing is set as well.
Old 11-03-2008, 08:20 PM
Restricted User
willyfastz's Avatar
If you want torque you have the wrong cam. Do a search and you will see the MS4 is not a torque cam. I dought the tuner is your problem in this case. And I wouldn't raise your compression to band aid a poor cam choice.
Old 11-03-2008, 09:21 PM
Old SStroker's Avatar
Yeah, get some professional help sorting out your engine. It is available, right *****? You need to tell the engine designer the results you want, not how to get there.
Old 11-03-2008, 10:16 PM
massls1guy's Avatar
To the OP - have you seen the dynamic compression ratio (DCR) threads in this room:
https://ls1tech.com/forums/showthrea...dcr+calculator
It's basically a way to figure out what compression ratio a cam requires to make good torque without detonation on pump gas. I don't think the MS4 will plug directly into the spreadsheet but you can use some similar comp grinds to get an idea.
Old 11-03-2008, 10:23 PM
brad8266's Avatar
That cam is not well suited as a torque/low end power cam. Its valve events are very favorable in the high end range which is what is was designed for. The overlap and early intake valve closing point will limit the amount of torque that cam can produce.
Your head design and gaskets will make a difference but you dont have much room to work with in terms of chamber size when you run a cam that large so getting a tight quench area is likely out of the question.
I have a medium cam 232/236 on a 112 and I made over 450 RWHP and 415 RWTQ and the car pulls great down low and on top. It doesnt always take a huge cam to make good numbers.
Old 11-03-2008, 11:35 PM
Stocktonz28's Avatar
Nice numbers. It seems you got jipped on your dyno tune.
Old 11-04-2008, 08:23 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Dynamic compression is the name of the game as was mentioned earlier. Also, who ported the heads, could they have taken out too much runner volume and hurt velocity? You didn't specify who's heads they were, so I'm just asking.
Old 11-04-2008, 09:03 AM
dankl's Avatar
Cam is a top end, horse-power making cam grind. Replace your bottom end with more cubes and you'll get more torque. Other than that, put in a smaller duration cam.
These 346cid's are notorious for "lacking" torque when pulling horses out of it. More HP usually results in a TQ drop, from what I've seen. Obviously, this is not always the case.
Old 11-04-2008, 12:53 PM
Clevite Kid's Avatar
Good advice, and when you put more cubic inches under those heads, the compression ratio will go up automatically. This will help (a little) the dynamic compression ratio as well. If you can advance the cam a few degrees (2 to 4) you will improve the DCR and pick up a little lower RPM torque, too.
Old 11-04-2008, 01:16 PM
87silverbullet's Avatar
Easiest fix would probably be changing out the cam. A shorter duration cam would yield a better torque curve but you will lose a lil hp.
Old 11-04-2008, 01:19 PM
Goldfinger911's Avatar
DCR and Timing my friend. Lots of good advice here.
How much timing are you running through the mid range and top end? Can you post your tune that the Dyno Tune gave you?
Old 11-07-2008, 11:59 PM
Ok so what cam would you guys recommend that would work well with the ls6 heads. They are stage 1 cnc ported. The ms4 cam I didnt think was a bad choice. I found something interesting when I scanned my car with hp tuners. My timing was set at 25*. That seems low. On the last dyno run the guy leaned it out. I couldnt exactly tell but it looks to be in the 12.8 a/f ratio. My VE tables were not smooth at all they looked like shitt to be honest and my timing map looked even worse. I paid 400 dollars. Should I get my money back. The car pulled clean too 6700 rpms which is nice. I put the car in speed density and deleted the maf sensor and put a big *** intake tube to meet the fast 92/92 combo and also I installed a slp underdrive pulley. I think I should add timing. Are there any tuners on here that could help me out. Any help would be great I dont know how to post pictures on the threads. I could post my dyno graph if I knew how. Oh and I am putting a th350 in the car with a 3500+ torque convertor so I like the powerband of the ms4 with the ratios in that tranny. But any suggestions on other cams would be great. They are not that hard too change. Thanks for the advice guys it has been extremely helpful.
Old 11-08-2008, 12:01 AM
another question does a dyno jet read lower or higher.
Old 11-08-2008, 12:18 AM
JPH
JPH's Avatar
I agree.
Old 11-08-2008, 08:07 AM
Ok I got the wrong cam. Which one would be the best. To just keep saying I got the wrong cam is pointless. Would the v3 be a good camshaft.
