Goal: 400hp dream: 450 to the wheels
Hey what up fellas I have a 01 z28 vert its also an m6 and has 115k miles. This is pretty much a street car and only been to the track once out of the 4yrs that i've had it. I do have simple little bolt ons like volant cold air intake, SLP loudmouthII, hypertech programmer (which i'll be taking off soon and selling it), and a hurst short shifter. well for the past couple of months its only been garage kept and i take it out only on the weekends. My plan with my car is to get 400hp. What i got in mind is a good head and cam package, headers, put a 75 shot (just to say that i have it), porting out my stock TB, and doing all the supporting mods, and at the end get it tuned. well with all that said is that enought to get me to my goal? money is somewhat of an issue and would like to keep a budget but also i want dependability with these mods.
so my question is, can you advice of what kind of mods i should be looking at to get the dependability that i want along with reaching my goal of 400hp but 450hp would be my dream?
please state any questions/concerns about anything.
your help is very much appreciated
I've somewhat made up a list of mods that i may be getting and that other memeber have put on their cars and have received good results.
LS6 HEADS- PORT
LONG TUBE HEADERS, ORY WITH AFTERMARKET CATS
224-ISH CUSTOME CAM
SPRINGS
PUSH RODS
LS2 TIMING CHAIN
LS6 PORTED OIL PUMP
PORTED STOCK THROTTLE BODY
ASP 25% UNDERDRIVE PULLEY
OR
AFR 205 HEADS
224/228 CUSTOME GRIND CAM
LS6 PORTED OIL PUMP
LS2 TIMIN CHAIN
SPRINGS
PUSH RODS
LS6 HEADS- PORT
224-ISH CUSTOME CAM
SPRINGS
PUSH RODS
LS2 TIMING CHAIN
LS6 PORTED OIL PUMP
OR
AFR 205 HEADS
LS6 PORTED OIL PUMP
LS2 TIMIN CHAIN
SPRINGS
PUSH RODS
Either of those setups will get you over 400rwhp. I did 393, then after I got a retune I picked up 3 tenths & 4mph @ the track, so I'm assuming I'm a little closer to 400 now and I'm cam only. From what I've seen, those setups should typically get you in the 420-430 range. 450 will more than likely require a bigger cam than a 224. I'm just speaking generally here, I know there are a few guys that are the exception.
cool cool how about a cam which is 228/230... that will be the next option for my dream goal, right?
so does anyone have a rough estimate of how much option number two will cost?
and this is me and a buddy doing the swapping and whatnot...
where can i get my 243 p&p. Iam assuming this is another way of saving money right?
**note: i am little new at this and i am trying to keep up with the verbage and i am currently in the process of learning proper mods and will be doing the swapping with a buddy that is a lot more experience than i am...thanks for the patience
Boltons plus a wet kit.........there is a cheap way to do it.[/QUOTE]
n2o is pretty much the last thing i would do. i would like the motor to last and not wear it down fast..But thanks for the input man its appreciated..
Don't think you have to go donkey dick to get 450wrhp.
Chris1313 has over 420hp with just a 230/230 cam, add AFR205 heads and you would be around 450rwhp.
With that 224/228 + the AFR heads and a good tune I think you can come within the realm of 450rwhp.
Donkey Dick cams + **** budget heads have a hard time even hitting 430rwhp; do it the right way.
to the OP:
check the classifieds, and the regional clasified to find a nice set of 243s. Im not sure about this so it might take a little more research :flame suit on" a set of 243s might outflow a set of budget 5.3s. i dont know for sure, but the bigger valves in the LS6 heads it would make sense, but the higher CR of the 5.3s might make up for it. That is just another alternative im throwing to you
or you go donkey dick cam only at first, then a niiiiice set of AFRs or PRCs and shoot for 475+ NA
alright thanks fellas for all the input. so pretty much these type of heads, PRC 220cc 5.3L Stage 2.5 CNC Ported Heads, should not be considered or in your opinion what do you guys think?
i kind of do like the price, 12 hundred...
