Why is my car going through oil
Seems like my car is going through oil pretty quick lately. I have added a quart and half probably 3-4 times since the end of september. Seems like its always low after I race it. After last time of adding oil I have only made 3 passes and 2-3 weeks of DD duty. This kind of concerns me it never use to be like this. What could be going on here?
take off your throttle body and check for oil. i know oil blows into the pcv line and into the top of the throttle body. i was getting a lot of oil consumption that way. then i put a small vent filter on the valve cover and put a cap on the fitting on top of the throttle body. and no more oil consumption.
but like stated before you could be getting a lot of blowby past the rings. does your car smoke a lot under full throttle? that could be your case.
I would check out the entire PCV system for other bad hoses & you may want to replace the valve as well.
The sytem may just need servicing ,could save you a lot of time and money.
Good luck, I hope it's something that simple.
Wildmouse
Wildmouse
