200 shot on this motor setup?
I am pulling the current motor to rebuid it with these parts, unless you guys say it can't be done.
So far the plan is
-Scat I beams w/ARP rod bolts
-diamond pistons
-nitrous outlet plate (78mm), single stage
-Walboro 255 pump
-making low to mid 400's on motor
Will the motor handle it reliably? Especially since it's single stage?
Also what rings to get?
Will I be fine with ARP bolts instead of studs?
Also, what is the highest compression i should run?
I'm on a budget, that's why I was thinking scat Ibeams.
thanks in advance.
So far the plan is
-diamond pistons
-Walboro 255 pump
thanks in advance.
OWN3D BY MY PROF!
They will, but pushing a big shot will be iffy. I think they're rated for 750 flywheel. That should be close to what he's pushing. They have a buffer zone built into them, but I wouldn't want to test it for too long.
Nozzle wise. Dave's plate is one of the baddest designs out there. Ron@Vengeance built a car using the 92mm version of that plate and has been spraying a 300 shot for a while.
I think the Scat rods will be fine for the 200 hit(but anymore I do think you should upgrade to a better I-beam or H-beam). I'm using their I-beams and the only reason I went with them was because of RPM I planned to turn. Otherwise I would have stuck with the stock ones.
