did i go to big with my choice of cam?
Old 12-13-2008, 10:44 AM
02 T/A 984's Avatar
Default did i go to big with my choice of cam?
i got a Torquer V.3 in my M6 T/A.....starting to wonder if i went to big for the street....the car has good street manners....but it seems like the torque is really low....me and my buddies usually run each other from 20-90 and they usually pull away from me pretty good in the beginning this cam dont start pulling really hard till up top........so did i go to big?
Old 12-13-2008, 11:03 AM
Irocss85's Avatar
what rear gear you got? and went too big , depends if that is your goal? or drag racing 1/4 mile more important?
Old 12-13-2008, 11:09 AM
02 T/A 984's Avatar
it's just stock rear end with 3.42......goals r just to have a fast street car for racing from a roll
Old 12-13-2008, 11:10 AM
Restricted User
1BAD_LS1's Avatar
from what i understand that cam doesn't start making good power till 4500-5000rpm. the ls1 likes the rpms. no cam really makes much power befor like 3000-3500rpm.
I am just going off of what i have learned in my search for the best dd h/c....so that might not be correct. Im new to the ls1.
s346k's Avatar
232/234 112 lsa cam too big? hahahah
Old 12-13-2008, 11:13 AM
Restricted User
1BAD_LS1's Avatar
i am undecided between the 228 and the 233...i dont want to make a big $$$ mistake but you have to learn somehow. Everyone has a different idea of what is best so i guess ill just have to do trial and error. Till i find what i like. lol
Old 12-13-2008, 11:23 AM
Irocss85's Avatar
well if street racing is your goal, prolly would have been better with the 224/227 cam as the power band is a little wider, and starts at a lower rpm.
but if you swapped in 4.10 gears, I think you'd be happy. and it wont hurt you really in gas mileage it'll just make you cruise 1 gear higher then before. say, driving 40mph down the road, now you'll be in 5 gear instead of 4 for instance. but it would make your car rev alot fster, and get you into the higher rpms where your cam really shines. Id do that instead of swapping cams again. IMHO you have a great street cam. also, you'll want to shift near 6300 rpm to get the most out of it. if you shift lower your just goin to spend too much time in the low rpms after the shift.
Old 12-13-2008, 11:26 AM
ja_engineer's Avatar
You could try playing with advancing the cam and see if you like it better.
Old 12-13-2008, 11:27 AM
02 T/A 984's Avatar
IROCSS85....that makes alot of sense i should put a 9 inch moser with sum 4.11 gears i would guess would be the best ratio would u agree.....car is a M6
Old 12-13-2008, 12:00 PM
First Collision's Avatar
4.11s will work fine.
Old 12-13-2008, 12:04 PM
02 T/A 984's Avatar
will i need bigger tires if i add a moser rear end and 4.11 i currently have the stock 16 inch tires
Old 12-13-2008, 12:14 PM
01ssreda4's Avatar
i have ridden in a car with that cam and 4.10s. it is absolutely sick at/over 3-4 grand.
Old 12-13-2008, 12:16 PM
02 T/A 984's Avatar
SWEET!!!!...thats what i want to hear
Old 12-13-2008, 12:32 PM
95 Z28's Avatar
I've got a really similar cam in my car (F14 highlift) and I think it's too small .
Old 12-13-2008, 12:37 PM
SladeX's Avatar
its in the gearing, you just need better gears (4.11 with a 9 inch would go nicely, 4.10 and a 10 bolt = borrowed time.)
Old 12-13-2008, 01:39 PM
Irocss85's Avatar
yeah agree about the borrowed time, except he doesnt drag race. only roll race. but either way, no, stay 26" tire. what tires u got now? it really is a great matchup.
Old 12-13-2008, 04:15 PM
00silver6's Avatar
4.11 9in damn were in the same boat thats what i need
