are 243 heads worth the $ over 317 on a carbed lq4
Old 12-13-2008, 04:35 PM
retro1977's Avatar
Default are 243 heads worth the $ over 317 on a carbed lq4
Have a 04 lq4 that will go in my s10. Iam planing on a single plane w/carb. Are the 243 worth me getting? this will be a street / strip truck. rest of combo is th350 w/4000 conv. 9inch w/4:11 gears truck should be around 2800 lbs. also dont want to run into and ptv issues. have seen plenty of this combo's run good. would like to run in the 10's if I can. any combo's out there with stock 317's or 243 or ?
Old 12-13-2008, 05:12 PM
5_02ls1's Avatar
you will gain some compression and thats about it...the flow numbers are close...
Old 12-13-2008, 06:11 PM
retro1977's Avatar
Yeah I cant see spending 500 or so unless the gain was worth it. anyone else
Old 12-13-2008, 06:12 PM
Monroe98SS's Avatar
I would use the #243s myself and put more SCR in the motor. With your camshaft profile(whatever that might be?), I would rather you have more compression in it.
Old 12-13-2008, 07:40 PM
retro1977's Avatar
could I mill the 317 alittle?
Old 12-13-2008, 07:43 PM
Formerly darynC-10/23/10
Daryn's Avatar
yes just make sure you check your new pushrod length and your ptv
Old 12-13-2008, 08:21 PM
retro1977's Avatar
how much would you mill off them?
Old 12-14-2008, 10:51 AM
XtraCajunSS's Avatar
Compression is your friend.
You will have to mill the snot out of those 317's to get where you need to be. It just depends on what your goals are. You could mill the 243's a little to bump the compression even more. Go here: http://www.csgnetwork.com/compcalc.html play around with some numbers and see where you end up. FWIW, you will lose ~1 cc of chamber for every .006" milled on stock heads.
I would shoot for a minimum of 11:1 for any decent cam.
Shane
Old 12-14-2008, 05:39 PM
retro1977's Avatar
I heard you can get 243 new from about 450 from patriot is that the best price? and this will only be a weekend /track truck. as long as I csn run 93 or so I will be happy
Old 12-15-2008, 07:47 AM
dre2013's Avatar
the 317s are good heads if you mill them enough..what cam are you going to run?
Old 12-15-2008, 08:34 AM
1969mach1's Avatar
I dont know, if they do they don't post it on the site
Here is the best price I have found on 243 heads.
http://www.sdpc2000.com/product/1257...dAssembly.aspx
