oil pump
Old 12-15-2008, 09:02 PM
hawk18's Avatar
Default oil pump
is ls6 oil pump a good upgrade for ls1 camswap performer
Old 12-15-2008, 09:04 PM
Cvaught's Avatar
I woudl aslo like to know. I know a lot of people use ported ls6 pumps, but will a regular ls6 pump do fine?
Old 12-15-2008, 09:12 PM
405HP_Z06's Avatar
The LS6 oil pump is now the stock replacement for the LS1 and it is an upgrade over the old LS1 pumps. Porting one is easy and just takes a little time. Katech sells a shim to increase pressure or you can use washers, etc.... If you don't want to port, an out of the box LS6 pump is plenty adequate.
FOR YOUR INFORMATION, here's a document I assembled showing how to port an LS6 oil pump: Download
Old 12-15-2008, 09:31 PM
jsteele90's Avatar
worked good for me
Old 12-15-2008, 10:20 PM
airmaxon1's Avatar
i have the reg. ls6 oil pump, no problems after cam swap
Old 12-15-2008, 10:53 PM
the_merv's Avatar
I have heard good things about the LS6 one, I'm using a Melling HV.
Old 12-15-2008, 11:11 PM
JPH
JPH's Avatar
Stick with your melling.
Old 12-16-2008, 02:48 PM
SOMbitch's Avatar
I am with Merv and JPH
The Melling 296 pump has 18% more volume so I decided it was worth the extra 30-40 bucks.
Old 12-16-2008, 03:10 PM
the_merv's Avatar
Oh yea, trust me that one isn't coming out for anything..
To the OP, if you can get a LS6 for a good price, go with that, but the Melling HV will perform better hands down.
Old 12-16-2008, 04:26 PM
sublime1996525's Avatar
I just put a melling in my 02 Z06 so I have a Z06 pump sitting around if you want it? Make an offer.
Old 12-16-2008, 06:23 PM
01ssreda4's Avatar
i used a melling 295 which is a standard volume standard pressure.
