Help ASAP broke braided ground wire
Old 12-20-2008, 12:09 AM
99tankta's Avatar
Exclamation Help ASAP broke braided ground wire
I need some advice on what to do. I going to install my new motor H/C and i just saw that the fkn braided ground wire that goes on the block has broken in half ...can i just soder or soilder (dont know how its spelled) it back together ..if not what can i do to replace it...
Thanks to all who chime in
Old 12-20-2008, 12:24 AM
1BADAIR's Avatar
the one from the 02 connector to the frame rail on the drivers side?
if it can't be repaired or you can't find a similar peice at a parts store run a wire with eyelets on each end
Old 12-20-2008, 12:33 AM
dc8fixer's Avatar
I would think a yellow butt splice would work fine...
Old 12-20-2008, 12:41 AM
99tankta's Avatar
its the one that goes from the block to the body on driverside
Old 12-20-2008, 01:19 AM
GA95DCMSS's Avatar
You can solder it until you get a new one. Just make sure it has good coverage and has a good bond.
Old 12-20-2008, 04:09 AM
the_merv's Avatar
Go to the Junk Yard and see if you can find one..
It's a little bigger than a 10GA..
Old 12-20-2008, 09:16 AM
99tankta's Avatar
thanks guys
Old 12-20-2008, 12:43 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I actually got a replacement for mine at Walmart - oddly enough, they had a large gauge wire with eyelets that was about the right size, and it bolted up no problems. Found it back in the automotive section.
Old 12-21-2008, 12:21 PM
garrettpen's Avatar
there's a brand called motormite that sells them. part number 85669
Old 12-21-2008, 02:39 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
any auto part store sells them. look were the battery cables are. and they should have ground straps around that area
Old 12-21-2008, 06:50 PM
TJ
TJ's Avatar
every autopart store should have them with the battery cable goodies.
Quick Reply: Help ASAP broke braided ground wire
