which be bettr for my setup
car is a 01ss
3600-3800 stall and built 60e
hooker lt's into 3' ture duals
4.10's and 28's
lid and ported t.b.
75-150 shot wet
would a 230/230 .600/.600 114 or a vindicator be better
car will be DD and see some 1/8 mile runs
4.10's and 28's
lid and ported t.b.
75-150 shot wet
if u are stuck on using stock gears 3.23 and a smaller stall i recommend the 230/230...cause they work great together, if you wanna go bigger like the vindicator the drivability is going to be worse on the street, u are going to want at least a 4000 stall, and step up the gears...
overall though the cams are close, you will give up some bottom end with the vindicator but gain it back up top, i bet they are pretty close to a wash in the end...
