Max lift for yellow LS6 valvesprings?
I've been searching, but I haven't been able to find an answer. What is the maximum lift that yellow LS6 valvesprings can accomodate safely? I'm getting ready for a cam swap, and the cams I'm considering are in the .547 - 0.581 range.
I think the 02+ LS6 cam had lift specs of .551/.547, so it sounds like the yellow springs should handle 0.547 safely.
What about the 0.581 lift cams -- would the yellow springs be a reasonable choice here, or would I be pushing them too far? Would I need to step up to some Comp 918's?
Thanks
Thanks
