LSX Intake manifold power gains on stock cubed heads/cam car
Old 10-01-2003, 10:21 AM
verbs's Avatar
Default LSX Intake manifold power gains on stock cubed heads/cam car
I see tons of questions about the effects of the LSX on stocked cubed heads/cam cars, and whether or not you a 90mm TB and 90mm FAST manifold would be worht it for a stock cubed car.
I don't think the 90mm manifold and TB are worth it unless you plan on going w/ bigger cubes down the road.
I think some LSX benefits come from port matching and for those of us who make lots of power above 6500-6600rpms when the ls6 intake seems to crap out a bit.
I still see the ls6 intake as the bottle neck on cars with high flowing heads.
The only negative I see is that gains will only be from 4500rpms and up, which doesn't make it as worth it for cars shifting in the 5500-6000rpm range.
Old 10-01-2003, 10:29 AM
Mirek's Avatar
Default Re: LSX Intake manifold power gains on stock cubed heads/cam car
From what i understand the ls6 intake should be sufficient for most head/cam combo's. There would be no benefit to my c1 cam/stock head set up. I'm going with the ls6.
Old 10-01-2003, 11:28 AM
verbs's Avatar
I don't think most heads/cam owners are looking for "sufficient" power or else they wouldn't be driving heads/cam cars to begin with
Old 10-01-2003, 11:40 AM
Nickn20's Avatar
I can't wait to slap a LSX with a 90mm TB on my 422, I hope this product turns out to be really good, not a flop like that aluminum thing.
Old 10-01-2003, 11:41 AM
Fireball's Avatar
I'm waiting on this answer before I plunk down 800 bones for that piece of plastic
Old 10-01-2003, 01:06 PM
Scalpel's Avatar
I also can't wait to slap this beast w/90MM tb on my 427
Old 10-01-2003, 01:07 PM
crewdawg16's Avatar
It is a lot of money to be spent on a 3-piece plastic intake. Not to mention with the 90, you will want the bigger TB and MAF, even though MAFs only go up to 85mm. Oh well, I guess the first GP will show us whether or not it's worth it.
Old 10-01-2003, 01:29 PM
BurnOut's Avatar
I dunno... it seems that cylinder head flow drops considerably with the intake in place... by something like ~30 or so cfm if I remember correctly. If a new intake could halve that flow loss (to a 15 cfm drop between open/radiused port flow and through-the-intake flow), it could be worth some power even on the H/C cars.
It'll be interesting to see.
Old 10-01-2003, 01:39 PM
30th TA 0219's Avatar
considering the LS6 intake was like $500 when it came out, $800 seems like a steel, especially for the big boys. Hell, the fact that you couls always port or make direct n2o ports makes it worthwhile. Now, yes, you need to factor in the TB, but if you have an LS6 already, you can recover $400+ of your cash right there selling the intake/TB. It will be a loooong time beofre I need one, but can't wait for them to come out. Then I'l be able to get an LS6 cheap
Old 10-01-2003, 03:22 PM
rob-ss's Avatar
I'm with you. No one has showed me any hard #'s as far as HP/TQ with this thing yet.
Old 10-01-2003, 05:09 PM
Black Sunshine/ 00SS's Avatar
The simple truth is that we wont know if it will produce any gains, until some independent testing is done (by sponsors and member of this board). I've learned that you cant take the word of a manufacturer as to the gains.
I'm taking the wait & see approact on this one.
Old 10-01-2003, 06:53 PM
Ragtop 99's Avatar
You'll have a hard time selling a used LS6 intake for $400, if this thing puts out the big numbers because a lot of used LS6 intakes will become available. ported TB's will also loose some value too.
Old 10-01-2003, 07:07 PM
Dave Carney's Avatar
Yes, I just picked up a brand new one on Ebay for $315 and $25 shipping, I think used prices will fall to $225 to $250 if the LSX hits it's marks.
Old 10-02-2003, 07:12 AM
Well, I said intake/TB combo. And I personally don't care, I'm just trying to encourage peeps into getting it so I can get an LS6 manifold
Even better news ofr me!
Old 10-05-2003, 10:10 PM
SStrokerAce's Avatar
On the TB front...
The stock unit can't go to 78mm to match the 78mm LSX intake, but it can go oversize, so it's going to take more than a home port job to get the most out of those things.
On the big 90mm versions, those guys are going to run the FAST TB anyways.
We are selling the LSX intakes too ($795) and I will get a 90mm TB in to see what I can do to it.
Bret
Old 10-05-2003, 10:14 PM
Beast96Z's Avatar
I'm still trying to figure out if the stock TB will bolt up to the 90 mm version. This way I can get the larger hole, and upgrade when I go to bigger cubes. No need for a 90mm TB right now. Anyone know?
Old 10-05-2003, 10:53 PM
verbs's Avatar
Or better yet, can you run a 90mm TB on a stock cubed motor and not lose any power, so that you can have all the necessary components when you upgrade to a bigger motor?
Old 10-06-2003, 02:07 AM
AZZ28's Avatar
I herd that the 90mm version will not be out for some time. Only the 78mm versions will be available later this year. I'm with 30th TA I will ****** up one of the used LS6s off of somebodys big cube motor.
Old 10-06-2003, 06:31 AM
Camaroholic's Avatar
And I'm hoping the 90mm has some room left for grinding so that I might be able to bolt a 95mm Mustang TB on to it (with an adapter plate).
Bigger is better. I have a 58mm BBK TB (and ported intake) on the 4.3L L99 motor in my '94Z, and watching the datalogs, it doesn't pull much vacuum at WOT (MAP hovers near max). There are NO problems at all running a larger TB.
-Andrew
Old 10-06-2003, 10:23 AM
Dont have to wait, I have a LS6 intake FS in the FS section, $300. EMAIL me if you want it.
