Need ideas for getting valve keepers loose
Old 10-15-2003, 12:45 PM
HumpinSS's Avatar
Default Need ideas for getting valve keepers loose
when working on #8 and limited space. Are there anyother ways of freeing them without having to bang on it to hard. This is the tool I have been using which worked great on all the other springs
Old 10-15-2003, 01:36 PM
dropkick's Avatar
Default Re: Need ideas for getting valve keepers loose
That #8 valve spring can be a little tricky. Install your spring compressor and compress the spring until the valve stem starts comming through the top of the retainer. Then insert the tip of a screwdriver between the locks and tap on the screwdriver. You might have to compress the spring a little more and tap on it again. You should be able to loosen the locks. Good Luck !
Old 10-15-2003, 02:13 PM
HumpinSS's Avatar
Thanks. That is the only one i have left and its kicking my ***.
Old 10-15-2003, 02:18 PM
I can shift faster than you.
Jason99T/A's Avatar
Tap on the retainer with a socket and a small hammer a fwe times to loosen the locks. Then, you shouldn't have many problems after this.
Old 10-15-2003, 02:43 PM
HumpinSS's Avatar
I wish it were that easy with #8 I can barely get my hand back there much less with a hammer.
Old 10-15-2003, 02:55 PM
jmX
jmX's Avatar
If you put that cylinder at TDC, when the valve hits the piston the locks will come free from the retainer. Sometimes they'll even go flying, so make sure you have extras, or a net
Old 10-15-2003, 03:08 PM
jrp
SN95 Director
jrp's Avatar
i used a hammer and small wrench to tap the retainer, and head jmX's warning about making sure they dont fly off :o
