LS7 Lifters
Old 03-04-2009, 07:06 AM
importkiller_SS's Avatar
Default LS7 Lifters
i've searched and searched but havent found much info about LS7 Lifters except their a cheap and good.
would anybody recommend them? or would you prefer any other lifter instead? has anybody had any problems with the LS7 lifters?
Old 03-04-2009, 10:33 AM
badazz99ta's Avatar
i have ls7 lifters myself. they are great and i would recommend these. i think the caddy's are a little better, but a little pricey.
Old 03-04-2009, 10:54 AM
thunderstruck's Avatar
i have them also, no problems yet !
Old 03-04-2009, 11:39 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
They are an OE replacement for the LS1 engines. No upgrades or anything, just packaged in a set of 16 by GM which saves you money. We run them in many of the cars we build. They are not bad lifter for the average street car.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-04-2009, 01:34 PM
pillagenburn's Avatar
so LS7 lifters are identical to LS1 lifters?
Old 03-04-2009, 02:43 PM
Sube's Avatar
Not identical from what i know, but a stock replacement. You can't buy LS1 lifters anymore, GM replaced them with the LS7 lifter.
Old 03-04-2009, 02:48 PM
BYE RICE's Avatar
I run them.
They hold up well (so far) to an XFI lobe & comp 921's.
Old 03-04-2009, 02:53 PM
Casting number on case is same, internals are identical. GM superceded a couple old part numbers and you can buy them individually now, but for about $60 each. OR, buy them in a set of 16 from us for $119. They are a standard GM lifter that'll work in an LS1, LT1, older SBC, V6 cars, etc. They are not an upgrade perse, unless your existing lifters are worn out and need replaced!
__________________
Old 03-04-2009, 03:05 PM
quadman's Avatar
ok for a daily driver/weekend warrior car?
Old 03-04-2009, 03:08 PM
Depends on which springs/camshaft you run.
__________________
Old 03-04-2009, 03:10 PM
BYE RICE's Avatar
See sig.
I drive the car more than I should.
I've probably put 10k on them easy.
chris mac's Avatar
no problems from the set that i'm running... i am not too easy on my car, either!!! i did have 1 lifter that i had noticed that was cracked when i bought them new. i just took it back to the dealer and they gave me a new one...
good luck
mac
Old 03-04-2009, 04:12 PM
im glad to hear good about them... they fit my price range well.
Old 03-04-2009, 04:15 PM
how would they compare to "Comp R" lifters? or the caddy lifters?
Old 03-04-2009, 04:24 PM
BYE RICE's Avatar
-Caddy racing lifters are an upgrade to LS7's.
-I replaced a set of Comp R's that I had some issues with.
Comp R's are tricky to set up.
These are my cam specs..236/242 .615”/.612” 111LSA
Like I said.XFI lobes..Which are faster than XE-Rs but not as aggressive as LSK's..LSk's require solid roller...Comp said solids should be run with XFI's also,but somehow LS7s seem to be doing OK.
Old 03-04-2009, 04:33 PM
Come again? Who told you that? MANY run the LSK/XFI/XeR lobes on hydraulic lifters every day. It's not a big deal really.
__________________
Old 03-04-2009, 04:54 PM
BYE RICE's Avatar
Comp said that in the application guide in their catalog...
Old 03-04-2009, 04:57 PM
Link or screen shot?
__________________
Old 03-04-2009, 05:12 PM
1.8t's Avatar
I run the factory lifters on my comp LSL lobed cam and they have worked perfect *knock on wood*
Old 03-04-2009, 05:22 PM
BYE RICE's Avatar
I just looked on their latest online catalog. The XFI's are now listed as 'hydraulic roller'.
I don't even see LSK's listed anymore.
Trust me..I agonized over lifter choice when I was putting this combo together 2 years ago.
I distinctly remember seeing 'XFI/solid roller' in print.
Maybe they assumed that when they engineered those profiles,that they assumed that a hydraulic roller wasn't up to the challenge & that they we erring on the side of caution
I dunno..I just remember sweating it a little..But your shop(amogst other ppl) told me not to worry.
You were right..What can I say?
