Help! Found a small spring after oil change(pics)
Old 03-13-2009, 12:29 PM
flamingo-flaps's Avatar
Default Help! Found a small spring after oil change(pics)
I changed my oil the other day and attached to the magnet at the tip of the drain plug I found tiny metal shavings and a long, very thin spring. I expected metal shavings but not the spring.
I've had the cam in for 10k miles.
Old 03-13-2009, 12:35 PM
gayslowassNALSjunk's Avatar
Valve seal spring. Might want to replace it before you start burning a bunch of oil.
Old 03-13-2009, 12:38 PM
Thank you. Any idea on how long or hard it is to replace?
Old 03-13-2009, 12:40 PM
It's as easy as looking at all the valves and seeing which one is missing the spring. After that it's fixed by removing that spring, taking a pair of pliers to remove the old seal, take the new seal and lightly tap it on with a socket. Reinstall the spring and you're done.
Old 03-13-2009, 04:37 PM
I cant seem to find any online forsale. Would autozone have them? Could someone help me find some online?
Old 03-13-2009, 04:45 PM
rusty2198's Avatar
I aslo believe thats a valve stem seal spring I found one of those befor on a customers car and tripped the F-out. Afew months later car kept oilfoulding #2 plug and sure enough it was a valve spring seal. Don't buy after market get factory replacements
Old 03-13-2009, 06:23 PM
Grimes's Avatar
Yeah, go to GM for a replacement. It def looks like a valve seal spring
Old 03-13-2009, 10:37 PM
SEMI-RETIRED's Avatar
Not sure about the valve spring seal but I'm thinking it looks like the inside spring from the front or the rear main seals.
Old 03-13-2009, 10:42 PM
Full-Force's Avatar
pics can be misleading but it looks too long to be a valve seal spring
Old 03-13-2009, 10:45 PM
Trev_SS's Avatar
Looks like a valve spring seal. Get a GM one and be done. Good Luck
-Trevor
Old 03-13-2009, 10:47 PM
zxcasd's Avatar
Yeah, just buy the seal at the dealer for like $2 and get the Tim's Tool here in the forum or in Ebay for $30 shipped !!!
2 Hrs and you are DONE
Old 03-15-2009, 11:18 AM
I appreciate everyone's help. Will be getting a GM replacement, thanks!
Old 03-16-2009, 02:25 AM
Fb0dy0nly's Avatar
napa has felpro ones, $20 for 16 fyi. might be a good idea to replace them all.
