Pulling cam ??
Pulling cam ??
Am I correct that the 5/16 rod is slid into the two holes behind the cam Plate? If so, the left side slid in no problem, the right side however only goes in about 4 inches. spun the cam around a few times with no luck. Please advise, Thanks
Moderator
It's an aluminum dowl rod ground down to a flat edge @ a 90* angle, with an end to stop it from going in too far. Cost about $80. I think you can find it in the tools forum if you search. The rod you have should work. You can always use 8 pen magnets on that side if the rod it not working for you.
