Anyone having issues with AFR Heads
Has anyone had problems with the afr heads. I was told there might be reliability issues or they had some in the past. I am rebuilding my motor and staying with stock cubes on my 98 TA to keep cost down with my current 70mm frt mnt. Also would the assembeled afr 225 need any upgrades like valves or springs with a mild turbo cam and mild boost. Shooting for around 700rwhp.
Restricted User
If you order the head assembled and ready to go with the correct springs, then you can bolt them right up. It's the only aftermarket casting that has absolutely no issues with stock geometry or valvetrain components such as rocker arms, pushrod length, etc.
