heads for Comp 224/224
I have a '98 z28...mods in sig. This car is my DD. I am looking for a good set of heads that will compliment this cam in hopes of around 400rwhp. What do you guys reccomend? I Tried a search but didn't find much.
I have the TR224 224 112lsa and ported LS6 heads with other goodies and I am little over 400RWHP through a Strange 12 bolt. So like other said just get a cheap set of ported LS6 heads. You will be happy .
I found a set of 243 take off castings on ebay, but even sending them out and having them CNC'd to stage 2 from TEA, awsome deal on the heads and stage 2 im at 1300.00
I do believe that you not going to find much for under 1k thats worth all the time and effort, but there are deals out there. Check out TEA's website and see what they got.
my brother is running the torquer 2 in his vette with patriot performance heads
https://www.patriot-performance.com/...age=1&featured
AND IT HAULS ***!
AND IT HAULS ***!
Moderator
For that price Patriot performance is your best bet. Not sure you will hit your goal with budget heads though. AFR 205's milled to increase compression will definitly get you there and then some.
LS1Tech Premium Sponsor
Your best bet is to absolutely look in the dyno section & not take any one persons recommendation on what heads to go with. At the $1000 price our PRC LS6 Stage 1 heads will outperform any competitors heads near this price. Don't take my word for it though, read the dyno section & flow test whatever heads you buy. Over inflated flow numbers are common place on the internet, especially in the budget cylinder head market.
We didn't build the PRC LS6 head to be a budget head, we build it with all the features & technology that goes into our more expensive heads. The result is a cylinder head that constantly performs as expected & flows & makes power just like we advertise.
http://www.texas-speed.com/shop/item...d=649&catid=20
$1025 for these bad boys
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
