5.3 vs 5.7
Old 04-07-2009, 11:49 PM
chevyforlife's Avatar
Default 5.3 vs 5.7
this might sound stupid but what all is the difference between a 5.3 truck motor and the 5.7 that comes in the 2000 z28, is the 5.3 still an ls1 and what do you think the power difference is between the two
Old 04-08-2009, 12:00 AM
zdc590's Avatar
I heard the 5.3 weighs roughly 60 or so pounds more, also i think it has like 30 less horsepower. These are just things i've heard though, they might be off by a bit.
Old 04-08-2009, 12:40 AM
goober35's Avatar
327 vs 346. So almost 20cu inches. Less hp, less tq, more weight. I am unsure right now but i think they are the same stroke but the bore is smaller in the 5.3 witch is what makes it a 5.3.
Old 04-08-2009, 09:55 AM
fuzzyjk's Avatar
Many 5.3 engines are aluminum, so weight is the same (iron is about 65lbs heavier). The acc and pulleys, intake and manifolds are different than the Camaro and Corvette, but it is the same block so everything will bolt up. The pulleys will need to be changed if you want to run a LS1/6 intake but the truck intake is almost as good as the LS6 and much better than the ls1. With a proper cam swap, 400hp is not unreasonable in fact if you look for a L33 out of a 2005 or newer short bed crew cab Silverado (8th digit of the VIN is a B) it comes with 799 or 243 heads (same thing) and with a minor cam swap (baby cam or Z06) 375-400 almost guaranteed. Mod for mod expect about a 7-10% decrease in HP with the 5.3 over the 5.7.
Hope that helps.
Jim
Old 04-08-2009, 10:41 AM
NonGoggleGuy's Avatar
Depending on what gen 5.3 you're talking about, it is very comparable to the LS1. The Gen IIIs are either LM7 (iron) or LM4 (aluminum). The Gen IV LS4 pushes about the same as an LS1, because it uses the LS6 heads & cam.
The 5.3 truck motors are LS engines, so they should be the same block. The mounts may be a little different, but everything should be interchangeable otherwise. The LS1 has a bore X stroke of 3.90X3.62, whereas the 5.3 has a 3.78X3.62. That can be bored into an LS1.
Old 04-08-2009, 09:26 PM
ok cool all that helped me alot thanks for the help
Old 08-01-2009, 12:47 PM
L33FTW's Avatar
What do you consider a "proper cam" 224, 228? larger? Are you saying just an Ls6 intake, a good cam, and exhaust could get 400Wheel HP?
Old 08-13-2009, 01:21 AM
williamGT's Avatar
the LS4 doesn't have a LS6 Cam....just the heads
Quick Reply: 5.3 vs 5.7
