looking for cam with with rpm band from 2k to lower 6k
was wondering if anyone offered a cam that would make around 420+rwhp that i dont have to shift a 6500+. would really like to shift at or around 6200. any ideas?
Get an agressive lobe with short duration and lots of lift. Im going with Comp Cams newest LSR cam.
The 219/227 .607/.614 112 (#54-456-11) is rated 1500-6700RPM (my brother bought this one for his '00 Camaro)
or
The 215/223 .604/.610 112 (#54-455-11) is rated 1300-6500RPM
I heavily concidered both myself, but went with a 219/235 .607/.621 113 since I have CNC LS3 heads.
or
I would have to give the lobe specs.
This is a custom unit, I have a graph of a similar grind but a different LSA/ICL
That cam was a 230/228 .612/.588 110-1 LSA
The difference is yours will come on a bit sooner and is more exhaust biased.
I do not charge anything, if you like, just PM me and I will give you the specs to grind it.
what kinda car was that dyno from pred-z?
Cost vary from vendor to vendor.
TSP has good deals
Springs: Patriot Gold or PRC Gold (TSP)
Push rods: 7.425 in cam only application
Cam specs are:
Intake lobe 3016R
Exhaust lobe: 3724R
110 LSA
111 ICL
I recommend degreing the cam for best results
TSP has good deals
Cam specs are:
Intake lobe 3016R
Exhaust lobe: 3724R
110 LSA
111 ICL
100>125 shot
230/230 .612/.592 111+3 LSA
150>200 shot
Then a bit more exhaust is desired
230/232 .612/.595 111+3 LSA
150>200 shot
