ms3 Is it a good cam!!! what do i need
Old 04-19-2009, 02:16 PM
bad98camaro's Avatar
Default ms3 Is it a good cam!!! what do i need
I lookin to put in a ms3 in my 98 camaro z28. Can anyone tell me what good upgrades to do with the cam.
Old 04-19-2009, 02:19 PM
NightRider2000's Avatar
Heads built with springs and intake and possibly some fuel if you go crazy with the tune.
Old 04-19-2009, 02:35 PM
car mods
k&n cold air intake
85mm throttle body
ls6 intake
kooks long tube headers and y pipe
slp exhaust
373 gears
Stage 3 transmission from perform-a-built
3000 stall
Old 04-19-2009, 02:38 PM
317BORN's Avatar
yea like nightrider2000 said...heads, springs, pushrods...also the oil pump and timing chain
Old 04-19-2009, 03:09 PM
what timing chain and oil pump should i go with? im going with TSP Camshaft, PRC Spring Kit & Pushrod Package the CamPkg-2 for $689.99
Old 04-19-2009, 04:47 PM
TXZ28LS1's Avatar
Originally Posted by bad98camaro
car mods
k&n cold air intake
85mm throttle body
ls6 intake
slp exhaust
373 gears
3000 stall
you will definitely need more stall if u plan on running a MS3. u would need atleast a 4k stall.
Old 04-19-2009, 07:50 PM
ksk1980's Avatar
the setup your buying is the same 1 i just got and installed myself . i love it . only diff. between our cars is mine is a M6 w/ a ls6 intake and 4.10's in the rear end . it pulls like a **** up top . jst wish i had the extra $$ laying around to drop in a new set of heads.
Old 04-20-2009, 11:19 PM
fastz99's Avatar
I am thinking of getting the same cam package from TSP. What kind of numbers did you put down with your car and have you run it at the strip yet? Did you have to upgrade your fuel pump?
Old 04-21-2009, 07:01 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You can get a LS2 chain for cheap. It depends how much cash you want to drop on other parts
Old 04-21-2009, 09:31 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If you want a single chain we offer an IWIS chain as well as the LS2 chain for the same price. For double rollers, Rollmaster offers a full line-up to meet your needs. While you've got the pump off, it's a good time to go back on with the ported pump we offer. It gives you the benefit of more consistent flow of oil through the pump, and is shimmed to give you slightly more pressure as well.
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-22-2009, 10:03 AM
CMR_ls1s's Avatar
^^^^ there the person that could tell you everything. I have a MS3 and I plan on releasing the beast with a set of heads soon.
