LOUD Knocking Sound!!!/Rod Bearing?? (sound clip inside)
Old 04-20-2009, 06:53 PM
martinls1's Avatar
Default LOUD Knocking Sound!!!/Rod Bearing?? (sound clip inside)
This noise literally happened overnight! Never over-reved my engine. Engine has 80,000 miles on it, stock bottom end, very well maintained.
Went to start my car, and it sounds like someone is in my engine banging away with a sledgehammer! Thought it was coming from the bellhousing area, because you could feel the knocking noise from the clutch pedal and shifter. Noise is the loudest when cold, increases with RPM's. Oil pressure is NORMAL, not flickering. Engine seems to be running normal, then again never actually drove car out of driveway with the loud noise.
So removed transmission/clutch, started motor with just the flywheel on and noise still there.....
Ran car without belt, noise still there, so its not the supercharger or accessories causing the noise.....
Ran engine, disconnected every spark plug wire one at a time to see if I could identify rod bearing for sure, nothing noise stayed the same......
Drained oil, very little shavings on magnet, to really see have to get a magnifying glass, looks like sludge in a way.....
Took off valve covers, no lose rocker arms or broken valve springs.......
The only thing left is BEARINGS!!!!
Right? What do you guys think? Anyone had a spun bearing sound so LOUD??
Heres a clip: http://s250.photobucket.com/albums/g...ckingNoise.flv
Old 04-24-2009, 06:18 PM
martinls1's Avatar
Any thoughts? Is the repetition of the noise to fast to be a bearing?
Old 04-24-2009, 06:53 PM
00Silv4.8's Avatar
sounds like a paint can is stuck in your motor! prepare for the worst...
Old 04-24-2009, 07:16 PM
pontiac1998's Avatar
holy crap dude....that def doesnt sound good....i just did a head and cam package in my car and still have some ticking so im trying to figure out my issue still...
does sound like a lifter my have fell apart and is rattling around...so i would start there...pull the supercharger off and send it to me so i can keep it maintained for you...
i would start with the valvecovers and go from there...
good luck
Old 04-24-2009, 07:20 PM
hirdlej's Avatar
Sounds like perhaps a cracked lifter tray allowing the lifter to rotate....... Either that or a cracked flex plate. Look at the flexplate first if this is an auto car
Old 04-24-2009, 07:21 PM
hirdlej's Avatar
Listen to this LT1. Sounds like yours: http://www.youtube.com/watch?v=EodvVgyB5DE
Old 04-24-2009, 07:22 PM
Xtreme57's Avatar
One vote for the bearings.
hirdlej's Avatar
Even this 3800 buick: http://www.youtube.com/watch?v=zWDYSE_uD90
Old 04-24-2009, 07:26 PM
KingSS's Avatar
That sounds like a rod knocking to me but you never know. That would have to be a crazy loud lifter, ive never heard one tick quite like that before.
Old 04-24-2009, 07:54 PM
Old Geezer's Avatar
Cut the filter open, and be prepared w/ some Advil...
Old 04-24-2009, 08:17 PM
martinls1's Avatar
NO WAY dude, my car doesnt sound anything like those videos. My video/sound clip is with the transmission and clutch off the engine. The only thing on is the flywheel.
Like I said before, I have the valve covers off and none of the rocker arms are loose.
I even took the timing chain cover off and everything looks good.
Old 04-25-2009, 04:24 AM
9secondsflat's Avatar
its a bad lifter...i had the same sound in a buick gn, a rod is a deeper sound and not as metallic
Old 04-25-2009, 05:32 AM
InsaneDomestics's Avatar
My guess would be a lifter. Take your valve covers back off and push down on the lifter side of the Rocker Arm and see if it goes down, I had two lifters that collapsed and it sounded somewhat similar. A knocking sound is so hard to tell what it is because there are so many things it could be. You never really know until you tear into it?
Old 04-28-2009, 02:32 PM
martinls1's Avatar
Update Well, were all wrong, that noise my friends is a bent rod in cylinder #7. The bottom of the piston was hitting the counterweight of the crank. I am so happy that I finally found the problem and also relieved that I didnt take out the engine for nothing! I guess my stock bottom end couldn't handle 7.5 lbs of boost!
Heres some pics
Old 04-28-2009, 02:40 PM
brianfromhawaii's Avatar
omfg!!!
Old 04-28-2009, 03:18 PM
Chrome355z's Avatar
holy ****! strange.
Time for a new crank with a little bit more stroke.
Old 04-28-2009, 03:56 PM
Marc 85Z28's Avatar
When you rebuild or replace that engine, make sure to replace the injector O-rings to prevent this from happening again.
Old 04-28-2009, 07:14 PM
KingSS's Avatar
I called that and no one payed attention. Nice, good luck with the rebuild.
Old 04-28-2009, 07:26 PM
Old Geezer's Avatar
Question ???
Why would an o'ring cause a bent rod??
It may be that the injector leaked down, and hydrolocked that cyl. When you cranked it, the rod wrinkled. The o'ring[s] had nothing to do w/ that phenom....
Old 04-28-2009, 08:18 PM
LS1Formulation's Avatar
You were lucky that thing didn't come unglued. Good thing you caught it.
Quick Reply: LOUD Knocking Sound!!!/Rod Bearing?? (sound clip inside)
