coolant leaking?
Old 04-27-2009, 09:26 PM
WS6-cobra killer's Avatar
Exclamation coolant leaking?
I have coolant leaking in the front of the motor.. no hoses are leaking.. Im thinking water pump, but no idea.. Please help.. 2002 TA WS6 Auto.. If it is the water pump how hard is it to replace? thanks for the advice in advance
Old 04-27-2009, 09:30 PM
elgp's Avatar
its easy if i correctly remember its just 6 10mm bolts
Old 04-27-2009, 09:33 PM
does it sound like a water pump issuse.. i have no clue..
Old 04-27-2009, 09:37 PM
elgp's Avatar
you probably do bro before replacing it remove the pump and inspect it for any signs of rust or cracks. and if does then thats your problem
Old 04-27-2009, 09:43 PM
67rsss's Avatar
Rust?
Water pump is the most likely source at the front of the engine. Could be a bad gasket, or a failing pump. Water pump is pretty easy to replace on these guys.
Old 04-27-2009, 09:49 PM
elgp's Avatar
Originally Posted by 67rsss
Rust?
you got a point its pure anti-freeze i wasent thinking about that
Old 04-27-2009, 10:01 PM
anywhere i can find a how to guide for changing a water pump for idiots!
Old 04-27-2009, 10:02 PM
elgp's Avatar
um let me try to find a link to help you out bro or google it
