Blown head gasket
Old 05-23-2009, 07:41 PM
Chris'stransam's Avatar
Default Blown head gasket
I am looking at buying a 2nd 99, the only problem is that it has a blown head gasket I think! The ls1 has water in the oil , but he clams he just changed the starter and he starter it and it just blew! ( just kinda hard to believe that)I have been spraying mine with a 100 shot and i have 145,000 miles on mine. He clams the car has never been sprayed , so i don't know. I NEED YOUR HELP PLEASE
Old 05-23-2009, 09:20 PM
conan's Avatar
Your looking to just buy the engine from him? or the whole car? If its just the engine tell him you want to see it with the heads off, so you can see if the heads or block have any damage.
Old 05-24-2009, 11:13 AM
Its the hole car , built trans full bolt ons .
Old 05-24-2009, 02:12 PM
conan's Avatar
How much does he want ror the car?
Old 05-24-2009, 06:38 PM
3,500.00 but it's not a ws6 ! Just a plain Trans-am .
Old 05-25-2009, 12:00 AM
conan's Avatar
Thats a tough call. It could be as little as changing head gaskets or a blown engine. Might want to make some kind of deal if the engine is shot and the block is toast.
Old 05-25-2009, 08:15 PM
Anyone else ?
Old 05-25-2009, 10:15 PM
Tyler valo's Avatar
This happened to my car during start up. As soon as I turned the key it sounded like bolts rattling around in a tin can.
Old 05-26-2009, 08:19 AM
Anyone else out there ?
Old 05-26-2009, 09:17 AM
Old Geezer's Avatar
B4 U hand him the cashola:
1. Compression check.
2. Pull the vc's, and see if all the valves are where they are supposed to be.
3. Cut the filter open.
4. Pressure test the cooling system.
If he changed the starter.. Could the previous starter have been trashed by a cyl full of water? [The engine was cranked, and that took the starter out?]
The "new starter" spun the engine, and this time the water lock jacked the head up, blowing the gasket?
As mentioned above... NO DEAL unless the heads are off, B4 the $$ change hands.
IMO, an "agreement" to correct the issue[s] AFTER the sale is pretty much unenforceable...
