408 needs
Old 06-01-2009, 11:44 PM
franksaltz28's Avatar
Default 408 needs
Ok so i have a set of ls6 heads, ms4 cam, and upgraded valvtrain. Im going to put these on a lq4 with a 408 stroker assembly. Is there anything that isnt going to transfer over to my car.
Old 06-02-2009, 08:42 AM
PAGregSS's Avatar
All of that will fit an LQ4 408 without issue.
Old 06-02-2009, 10:17 AM
Jon@Texas-Speed's Avatar
Basically everything will carry over to the LQ4 block. You will need to drill and tap one hole for the f-body alternator bracket but that should be it.
Jon
Old 06-03-2009, 12:15 AM
RyanSws6's Avatar
Yes all will bolt up.
I did price everything out and went with the Texas speed 408. For the total price of the short block you can't beat it!
Old 06-03-2009, 10:39 AM
For the buck, that seems like the best route. Im wanting to build it myself from an lq4 and piece together the 408 stroker. but even used it comes close to the same price, plus i need somebody to machine the block.
Old 06-03-2009, 01:35 PM
WSsick's Avatar
i know you are on a budget, but if the numbers are close, it may not hurt just to wait a little longer, save a few more dollars, and buy a brand new short block. but if its a big amount of change or youve alrady bought the parts, then make sure you find a reputable shop to do your work. do it once by doing it right. and no matter what, good luck with the build man! what are your goals?
Old 06-03-2009, 02:20 PM
RyanSws6's Avatar
IT was the best bank for the buck. I'm a numbers guy for a living. I priced it all out and John set me up at TS. I'll say the biggest difference in perf is the instant TQ and boom I'm at the rev limiter. I'm still getting bugs worked out of it. A4 is giving me trouble and I'd rather have a M6 for this setup. Beware of additional costs. Tunning is CRITICAL!!! Still working on that too. My 00 TA was bone stock so I had to buy everything and dropped 9k and counting. Just remember the weakest link rear and trans if an a4. Stick to your goals, mine was 95% street with normal driving and 2-3 track visits a year with maybe 6k miles a year.
Old 06-03-2009, 08:50 PM
yea i havent bought anything on the bottom yet. I was going to piece it together, but it just as cheep to buy it all at once and i get extra confidence.
