any1 ever have the crank pulley loosen up and back out?
looks like my crank pulley is backing off the snout. my ac belt feel off and the main belt slipped out of the grooves!! do u guys think i didnt tightin it enough???
Originally Posted by monkeyboy
yeah , using the stock one again is asking for trouble. i got away with using it again, but my friend was not so fortunate.
i used a brand new one!!!!
i will buy another new bolt. it pisses me off though that i have to rip the car apart again should i use lock tight?
Originally Posted by CANNIBAL
Yeah, having the remove the steering rack just for that is a PITA! No, the new bolts have loctite on them. If you want, just get the ARP bolt. It's reusable. ThunderRacing ---> has them. $25
ok I re-used a stock one the first time for a U/D pulley damn thing backed out and pulley came loose, then I just put a new one in. Then I swapped my cam and re-used again!! but put a little blue loc-tite on it and cranked her down still tite and have about 3000 so far
Originally Posted by pdd
how much should i torque the arp bolt to the crank?????
Originally Posted by Nickn20
don't skip on the bolt, or you might have some problems check this pic out!
