Oil Pressure Question
Old 06-21-2009, 02:51 PM
01trans am's Avatar
Default Oil Pressure Question UPDATE And new question
Alright I finally got my car back together after the h/c swap and the first time I go to crank it up I have no oip pressure. So I tear it back down and discover that I put the spacer in upside down
We get it all back together and crank it up again and after about 5 secs I had pressure of about 40. Well we never got it to idle right so I get in today and when I cranked it up it took about 5 seconds but it still showed I had pressure. I get it to stay on go inside for a about 2 minutes and come back out and I have no pressure
What can be causing this I really hate to tear it back down for the 3rd time I just want to drive the damn thing(but aint till I have pressure of course).
But I'm going to let it sit for about 2 hours then go see what it does.
Old 06-21-2009, 03:42 PM
Notmyvette's Avatar
Maybe a coincidence the sender is on its way out too.....
From what I read they're known to take a dump....including the one thats on the motor I'm rebuilding now never worked....it read like 180psi
Old 06-21-2009, 05:41 PM
01trans am's Avatar
Well I let it sit for a few hours. Went and cranked it up and after about 10 seconds and still no pressure
The only thing I can remotely think that could have gone wrong is I put some paper towels in the pan to keep the bolt from fall in the pan but I'm 90-95% I took it out. How can I just drop the pan out to see if thats it. I sure as hell dont want to take the font end back off.
Or is there something else to check
Old 06-22-2009, 03:22 PM
LS1Silverado05's Avatar
Have you verified that the O-Ring hasnt been pinched or torn? Quite common..
I suppose you could throw a sender at it if you wanted to just in case if you want to avoid teardown....but if it worked before....
Old 06-22-2009, 03:45 PM
01trans am's Avatar
Well its got a brand new sender and o ring (not that it couldnt be either).
I thought if the o ring was pinched it would show little or no pressure at all times but when I first cranked it up I had well over 40 then the next minute 0
Thats what making me think I left the damn rag in the pan and it is now clogged the pick up tube which is why I have no pressure
Old 06-22-2009, 08:34 PM
blkbird's Avatar
I hooked up a mechanical gauge inside the engine compartment to make sure i have good oil pressure at all times. Hook up a mechanical one and see what it reads.
Old 06-22-2009, 10:09 PM
Well a friend of mine had a pinched o ring and it showed psi but it was weak... I think 20-30 at idle, and came up to 40 or so under light accel... I dont know.. I just know that its a very common problem....
Course a rag in the pan could certainly do it...
Old 06-22-2009, 11:53 PM
Hi-Po's Avatar
Pinched o-ring will do that. A rag in the pan, is just bad. Bad bad. Stop starting the engine! You have verified the engine has little OP. Its time to start dis assembly again. Your going to do damage starting it if its either of the two. Rag or pinched oring.
Old 06-23-2009, 12:17 AM
Agreed.... its not just going to go away...
Old 06-23-2009, 07:26 AM
01trans am's Avatar
Oh I have already started to tear it back down so it aint getting cranked up till I figure out excactly what it is. Last thing I want to do is rebuild the motor.
Old 06-23-2009, 06:07 PM
vsocks1's Avatar
Good luck and let us know what you find!
Old 06-23-2009, 07:19 PM
allenwesley's Avatar
remember to come back and tell us what's the verdict...
Old 06-23-2009, 07:49 PM
01trans am's Avatar
I should be able to figure it out Thursday night I'll keep you guys posted
Old 06-25-2009, 06:03 PM
01trans am's Avatar
Okay so I had a few minutes to work on the car before going out and I was in the process of getting all the bolts out of the pan and noticed I never tightend the bolt under the k member. Could this cause the lack of oil pressure? I had the rest down to factory torque and didnt notice any leaking so I dont think thats the cause but wanted to get some more opions on this.
Old 06-25-2009, 07:40 PM
spy2520's Avatar
i doubt pan bolts had an effect on your oil pressure.
Old 06-26-2009, 12:20 AM
Yea, I dont think that was the problem... I'd drop pan or pull front cover...
Old 06-26-2009, 08:46 AM
01trans am's Avatar
Thats what I figured. Im going to finish tearing it down tonight and will report back on what I find.
Old 06-26-2009, 09:31 AM
avengedws6's Avatar
what kind of heads and cam? Is the oilpump a ls6 or stock ls1? My new ls6 oil pump when at idle is 40psi once it warms up, cold crank its around 70psi.
Old 06-26-2009, 08:09 PM
01trans am's Avatar
Alright I took it apart and the ring is fine but I found pieces of the paper towels in there. So ill be dropping the pan tomorrow.
Sorry if the spelling and grammer is not right I'm on my blackberry
Old 07-03-2009, 06:41 PM
01trans am's Avatar
Alright guys after a long process I finally got the pan out and the pick up tube was blocked off by peices of paper towels
Good news is I got it all back together and she seems to be running fine. Sounds sick
So thanks for all the help guys.
I'll be uploading a video of it running and I'll post a link here.
http://www.youtube.com/watch?v=A8jPOXLfCcE
